Schema electrische componenten CX
Rémon
Totaal aantal Berichten: 62
Geregistreerd: 09-07-2006
- CX GTI turbo 2
- XM 3.0 V6 24V Exclusive
Gepost: 19 december 2006 05:37 PM
Hallo Mensen
Misschien dat ik mensen kan helpen of blij maken met dit schema.
Ik kwam het toevallig tegen tijdens het surfen.
The item no. and diagram position refers to the Citroën and Haynes
manuals, the car position refers to the associated drawing.
No.
Description Position
Diagram
Car
1
Front cigarette lighter and lighting 189,203 j5
3
L/H rear cigarette lighter 124 n9
4
R/H rear cigarette lighter 132 n1
10
Alternator 86-89 b6
44
Digital display unit 67-74 f5
45
Battery 2 b8
46
Instrument panel 63-108
  211-214 g6,g7
47
ABS hydraulic unit 7-9 d6
51
HT coil cyl 1 & 4 57-58 c6
52
HT coil cyl 2 & 3 61-62 c6
54
ABS control unit 2-12 p6
57
Fuel calculator 47-48 j5
60
AC control unit 12-15 h5
76
L/H front window winder 113-115 j9
81
Interior heating control unit 27-30 h5
84
Water level sensor 86-78 e3
89
Door locking indicator 183-184 j5
90
Door locking control unit 178-186 j5
91
Remote door locking control unit 172-174 n5
92
Interior light timer 169-173 j5
93
Bulb failure unit 33,82-83,
  109,110,147,
  208,217 s8
95
Junction box g8
127
Lights on audible warning 174-175 g6
131
TDC sensor 60-61 c6
132
Flywheel sensor 58-59 d6
136
Vacuum advance waring 59-61 e3
137
Anti knock sensor 57-58 b2
140
Distance sensor 50 e7
141
Ignition ECU 54-65 c8
142
Injection ECU 36-48 g3
146
ABS L/H front wheel sensor #5-6 d9
147
ABS R/H front wheel sensor #7-8 d1
148
ABS L/H rear wheel sensor #11-12 r8
149
ABS R/H rear wheel sensor #8-9 r2
170
Boot light switch 198 s6
174
Boot locking switch 179 t5
180
Reverse lamp switch 33 d6
185
Stop lamp switch 147 h6
190
Handbrake switch 90 k5
192
Throttle spindle switch 45-47 b4
230
L/H front door switch 171 f9
231
R/H front door switch 172 f1
232
L/H rear door switch 174 k9
233
R/H rear door switch 175 k1
234
Glove box switch 187 f3
235
LHM pressure switch 81 e6
236
LHM level switch 8 e8
237
Water level sensor 76-77 e3
238
R/H front door lock switch 99 j1
239
R/H front door lock switch 98 j8
241
R/H rear door lock switch 101 q1
242
R/H rear door lock switch 100 q9
243
Boot lock switch 102 t5
244
Bonnet lock switch 97 a5
251
Height control switch 139-143 j5
254
Lights/direction indicator switch 209-215,
  107-110 g7
255
Windscreen wiper and horn switch 133-138,159 g6
268
Air recycling switch 16-18 h5
269
AC switch 20-23 h5
270
Max AC switch 17-19 h5
271
Air distribution switch 19-21 h5
276
Rear view mirror switch 152-157 h9
278
Blower speed control 23-25,29-31 h6
279
Heater control and lighting 103-104 h4
280
Supplementary air control 44 c4
285
HT coil suppressor 59 b6
  80 c5
295
Air horn compressor 160 c7
300
Starter motor 3-5 b5
302
Air flowmeter 40-44 b2
345
Fast idle electro valve 14 d2
365
Ashtray light 204 j6
370
Boot light 188 s4
375
Glove box light 187 f3
380
Engine compartment light 202 c6
385
Rear number plate light 218 t6
386
Rear number plate light 219 t4
390
Steering lock light 208 g7
410
AC compressor clutch 13 c6
430
Left front caliper 83-84 d9
431
Right front caliper 85-86 d1
440
L/H front side lamp 201 a8
441
R/H front side lamp 203 a2
442
L/H rear lamp 217
443
R/H rear lamp 218
445
L/H rear lamp cluster t8
446
R/H rear lamp cluster t2
447
L/H front fog lamp 206 a8
448
R/H front fog lamp 207 a2
457
L/H stop lamp 147
458
R/H stop lamp 148
460
L/H rear fog lamp 208
461
R/h rear fog lamp 209
462
L/H reversing lamp 33
463
R/H reversing lamp 34
470
Fuses g8
480
L/H front direction indicator 108 a7
481
R/H front direction indicator 111 a3
482
L/H rear direction indicator 109
483
R/H rear direction indicator 110
486
L/H long range lamp 211 a7
487
R/H long range lamp 216 a3
488
L/H head lamp 212-213 a8
489
R/H head lamp 214-215 a2
500
L/H front speaker 191 g8
501
R/H front speaker 193 g1
502
L/H rear speaker 194 k8
503
R/H rear speaker 199 k1
506
L/H front tweeter 192 h8
507
R/H front tweeter 192 h1
510
Front fog lamp switch 204-206 g5
511
Rear fog lamp switch 208-210 g5
Driver’s door window winder switch
519
R/H window
120-122 h8
520
L/H window
115-118 h8
521
R/H front window winder switch 120-122 h1
522
L/H rear window winder switch 125-127 k5
523
R/H rear window winder switch 129-131 k5
530
Sun roof switch *141 j5
532
Heated rear screen switch 162-164 j5
545
Interior light switch 166-168 j5
570
Hazard warning switch 109-113 g5
575
Cold start injector 38 b6
576
Main injectors 40-43 c3,c4
580
Fuel guage sender 94-96 q5
600
Front windscreen wiper 133-137 e4
608
Height control motor 140-145 j4
610
Sun roof motor *141 p5
615
L/H front window motor 116 g9
616
R/H front window motor 121 g1
617
L/H rear window motor 126 n9
618
R/H rear window motor 130 n1
621
Air intake motor 17 e3
622
Air distribution motor 20 g4
625
L/H front door lock motor 177-179 j9
626
R/H front door lock motor 181-183 j1
627
L/H rear door lock motor 177-179 p9
628
R/H rear door lock motor 181-183 p1
629
Boot door lock motor 183 t5
630
Fuel flap lock motor 179 s2
634
R/H engine cooling fan 9 a4
635
L/H engine cooling fa 9 a6
650
Engine oil pressure switch 79 d3
658
Blower fan speed control module 25-26 f3
660
Computer 50-53 g5
680
Windscreen washer pump 138 e1
683
Fuel pump 45 q4
690
Central interior lighting 165-167 n5
693
L/H interior light (sun roof option) #166 q7
694
R/H interior light (sun roof option) #168 q3
695
Front interior spot lamp 165 n5
698
Headphone socket 195-198 k5
700
AC pressure switch 13 c7
710
12V supply socket 123 k5
721
Radio connections 191-199 k5
731
Fuel injection relay 38-46 a2
733
AC engine fan relay 12-13 b8
734
Injector relay 35-36 a2
735
Main beam relay 215-216 g7
739
Height control relay 142-145 f7
743
Air horn compressor relay 159-160 c7
745
Blower motor fast speed relay 24-25 g4
750
Fog lamp relay 206-208 g8
756
ABS electro valve relay #5-8 d5
757
ABS protection relay #3-5 d5
772
Blower motor second speed relay 10-11 b8
773
Blower cooling fan inverter relay 7-9 b8
795
Lighting rheostat 97 g6
810
L/H direction indicator repeater (export) 107 e9
811
R/H direction indicator repeater (export) 112 e1
814
L/H rear view mirror 151-154 g9
815
R/H rear view mirror 155-157 g1
831
Interior heating distribution flap motor 27-31 g5
835
Engine oil level sensor 92-93 c4
837
AC evaporator temperature sensor 12-13 f5
838
Exterior air temperature sensor 71-72 a5
839
Interior air temperature sensor 30 j5
840
Water temp. Sensor 73-74 c4
841
Water temp. sensor (injection) 39 c3
842
Engine oil pressure sensor 91 c4
843
Engine oil temp. Sensor 70-71 c5
850
Engine cooling fan thermal switch 9-10 b6
870
Thermal switch (cold start injector) 37-38 c3
935
Blower motor 25 e5
945
Heated rear screen 163 r7
  r3
980
Door locking warning lamp 184 g8
C Direction indicator unit 108 g7
I Windscreen wiper timer 136 g7
R1 Engine cooling fan relay 6 g7
R2 Front window winder relay 128 g7
R3 Rear window winder relay 116 g7
R4 Heated rear windscreen relay 163 g7
# Special diagram.
Fuses, from the left.
No. Amperage Function
1 10 Reversing lamps.
2 25 Switch lighting for: Hazard warning, Front & rear fog lights, Dashboard and heater control, Digital display, Heating system, Direction indicators. Dashboard functions and warning lights, Audible lights left on warning, ABS and ABS warning lamp.
3 25 Heated rear window relay, Window winder relays, Brake lights, Windscreen wash and wipe, Height adjuster motor, Adjustable spot lamp, Rear view mirrors, Radio supply, Sunroof.
4 30 Engine cooling fans.
5 10 Hazard warning lamps.
6 30 Front window motors.
7 30 Central door locking, Interior lamp, Cigar lighters, Glove box light, Power socket, Radio feed, Boot light, Height control function, Digital display function.
8 25 Heated rear window, Horns.
9 30 Rear window motors.
10 5 Rear fog lamps.
11 5 Rear number plate lights.
12 5 Rear lamps.
13 5 Dashboard lights for front lamps and fog lamps, Lighting for steering lock, cigar lighter, ashtray, under bonnet, Audible lights left on warning.
14 Not used.
Groetjes Rémon
