Hello, can i speak french because my nederlands not good…
Dank u,
Luigi
Totaal aantal Berichten: 43456
Desole Luigi, ici le forum est en Neerlandais. Mais, tu peut ecrire en anglais si tu veut
ok thanks i want to know if there are a really difference between the motor 148HP & 160HP ?
A 160 horsepower version does not have a catalyst converter. The other one has a catalyst converter.
Thats the main difference.
yes i know but i want to know with power if there are a difference ? with max km/h and the 0 to 100km/h
the version normal it’s more powerfull ? thanks
Totaal aantal Berichten: 7072
- BX Sport MK2
- AX GT chic
Arjan Verkade schreef:A 160 horsepower version does not have a catalyst converter. The other one has a catalyst converter.
There are more difference, also in the ECU. I dont know the little details.
bx16valve schreef:yes i know but i want to know with power if there are a difference ? with max km/h and the 0 to 100km/h
A 160bhp version is faster! Like a 158 bhp mk2.
We have a dutch website with some specs:
I think you will be able to read the specs
XU9J4
The XU9J4 was fitted to early Mi16 and BX16V cars. It’s an alloy block with cast iron liners. The 16V head is an absolute work of art and a fantastic base for building a high output engine. Cars originally fitted with this engine had the Motronic 4.1 ECU (2 row connector). It was designed to run on leaded (or unleaded) fuel, so it did not have a knock sensor, oxygen sensor or catylitic convertor. It was later fitted with a Motronic 1.3 ECU, including a knock sensor. It was commonly known as the 160hp (119kW) engine and designated D6C.
It had many physical similarities to the XU9J2 (and XU5) version as fitted to many Peugeots and Citroens, but many parts are unique. Features unique to the 16V engines include stronger block, ribbed liners, fully counterweighted crankshaft, full floating gudgeon pins, lighter pistons and piston oil sprayers.
XU9J4Z
A derivative of the XU9J4, the XU9J4Z was also fitted to early Mi16 and BX16 cars, in markets requiring strict emissions controls, such as USA and Australia. In addition to compression and cam timing differences, these cars were fitted with the Motronic 1.3 ECU (3 row connector) and had a knock sensor, oxygen sensor and a catylitic convertor. Power output was 108kW (145hp) and was designated DFW.
XU9J4 / Z Differences
In addition to external sensors and the ECU , there are two main differences between these two engines.
1. Compression
This is achieved by different pistons. Whilst almost identical to the untrained eye, the flat top pistons have different compression heights. They can be identified by either a “Z” or an “X” stamped on the piston crown. The XU9J4Z piston sits a lot further down the bore.
2. Cam Timing
All these engines have the same inlet and exhaust cams. Differences in cam timing are achieved by different cam pulleys. Pulleys are stamped with either a “2”,“3” or a “4”. The #3 pulley is used on the XU9J4Z inlet cam to advance the cam timing 3 degrees (crank). This keeps the dynamic compression of the lower compression engine higher, increasing torque and driveability. Later XU9J4 engines were fitted with #4 pulley on the inlet. This advances the inlet cam by a further 5 degrees to a 106 degree centreline.
The cam timing and lift of these engines are very mild. They feature wide lobe centres to keep overlap low and give a smooth idle.
XU9J4
Bore (mm) 83
Stroke (mm) 88
Capacity (cc) 1905
CR 10.4
Power hp (kW) 160
Engine Code D6C
XU9J4Z
Bore (mm) 83
Stroke (mm) 88
Capacity (cc) 1905
CR 9.7
Power hp (kW) 149.5
Engine Code DFW
EngineCode CrownStamp Compression Height
XU9J4 D6C Z 37.12
XU9J4Z DFW X 36.28
liever 10 sterren in me ruit, dan 1 op me motorkap
thanks man its not only catalysor but a different motor, ohhh shit
if i broke my catalysor it will be change anything ?
but in the future my motor broke i can put the D6A ? i will must change the gestion motor ?
dank u mijn vriend
Totaal aantal Berichten: 1986
Geregistreerd: 07-05-2006
Welkom!
