Led Knipperlicht
DamianDS3
Totaal aantal Berichten: 32
Geregistreerd: 14-05-2011
Gepost: 24 november 2012 10:25 PM
Hi all,
  i did some test how work led bulb in turn signal light, and this is result
http://www.youtube.com/watch?v=hNa9-_ZjDJc&feature=youtu.be
in my opinion not bad… i didnt check yet night effect, but for sure is nice
gr
Damian
Wim van den Bergh
Totaal aantal Berichten: 189
Geregistreerd: 27-09-2012
- C25 2.5 TD Burstner camper
- 2CV Le Patron 3 cabrio
- Berlingo 1.6 16V Multispace
- 2CV AK 250
Gepost: 25 november 2012 11:36 AM
It would be nice to see the difference: traditional light bulb in one unit and LED in the other. Please film that and repost Wink
2CV AK250 652cc, 1960
Le Patron 3 652cc, 1984;
C25 Burstner 2500 Turbo Diesel, 1990;
2CV Charleston trapauto, 1996;
Berlingo 1.6 16v Multispace 2003
DamianDS3
Gepost: 25 november 2012 08:25 PM
Wim van den Bergh
- 2CV AK 250
Gepost: 25 november 2012 09:04 PM
DamianDS3 schreef:
you welcome
http://www.youtube.com/watch?v=sV25oIE0DyI
So the bulb is blinking slower and the LED version is on longer cause it has a head start
DamianDS3
Gepost: 25 november 2012 09:43 PM
Wim van den Bergh
- 2CV AK 250
Gepost: 25 november 2012 10:56 PM
With all due respect but at those prices i would leave things as they are. The webshop owner says it is a known fact that these LEDs cause errors in the electrical system that can be solved with more of his products.
DamianDS3
Gepost: 25 november 2012 11:56 PM
ahm ok good to know, lets see what he gonna answer. If led bulb have canbus, that mean they can not cause any problem, if still do that mean quality is sh.t you right for that price…
gr
Damian
W_H
Totaal aantal Berichten: 98
Geregistreerd: 21-02-2012
Gepost: 26 november 2012 12:02 AM
I think it’s very nice! Does it have about the same brightness as the original bulbs have? And do they also fit the front and mirror indicator lights?
Nitro+
Totaal aantal Berichten: 562
Geregistreerd: 13-03-2011
- DS 3 e-HDi 90 So Chic
Gepost: 26 november 2012 08:19 PM
@W_H: De koplampen en de achterlichten bevatten hetzelfde type knipperlicht, namelijk PY21W. Dus ja, ze passen ook in de koplampen.
Wat betreft de zijknipperlichten, die zal je helaas niet kunnen vervangen voor LED-versies. Het halogeenlampje, een W5W, zit namelijk helemaal verwerkt in de lampbehuizing. De lampbehuizig krijg je met gemak uit de spiegel, maar vervolgens krijg je de behuizing zelf met geen mogelijkheid uit elkaar. Daarom vervangt Citroën i.g.v. reparatie niet het lampje, maar gewoon de hele lampbehuizing.
DamianDS3
Gepost: 07 december 2012 08:15 PM
today i have tried to change signal bulbs in front lights… unfortunately normal leds blinking fast, when i use emergency lights all 4 than is ok… did anybody tried to fix led with canbus ? It fix fast blinking ? In the back lights is no problem because i can use resistors… in front is a little bit difficult.
Efect is very nice… so if anybody can help me how to fix front i will be grateful.
short movie from my car with emergency lights
http://www.youtube.com/watch?v=6-LZm7nYE1I&feature=youtu.be
