2 van de 5
citroen ds oververhitting probleem
> 11000 berichten
Totaal aantal Berichten: 11999
Gepost: 02 december 2019 12:15 AM
For bigger sized images: you can host photos externally, on sites like Flickr or MyAlbum what have you, then deeplink them here in a bigger size. It’s not totally optimal, admittedly, but it works.
SalsaChris
Totaal aantal Berichten: 910
Geregistreerd: 22-07-2011
- ID/DS Dsuper
Gepost: 02 december 2019 08:49 PM
Did you ran the car with or without the interior heating on? I had this problem after I removed the radiator for maintenance. Chances are that you have an air bubble there = highest point of the system.
Mr.Rubins
Totaal aantal Berichten: 37
Geregistreerd: 27-11-2019
Gepost: 04 december 2019 05:52 PM
some pictures
Mr.Rubins
Mr.Rubins
Gepost: 04 december 2019 05:53 PM
Mr.Rubins
Mr.Rubins
picture 4
Mr.Rubins
Gepost: 04 december 2019 05:59 PM
Citroen DS SUPER. this car have Engine is DX4, 2350cc, 115 hp, 5500 rpm, 2,3 liter. In registre documents in our country “specialists” write that it is ID 19 ? model, but this is wrong.
I found that in Citroen 1973 Year, 5 gang, DS Super must be with 2175cc engine but this car is with 2347cc engine 2.3 liter
And this car in Netherlands was with LPG gas. LPG gas pipes was wrong installed. now they will be off
Mr.Rubins
Gepost: 04 december 2019 06:03 PM
friends car look like this after repainting
Mr.Rubins
Gepost: 04 december 2019 06:05 PM
and 2nd photo. car was used this summer for wedding. but big stress because can drive only 25 min. till church Smile after it overheated.
Mr.Rubins
Gepost: 04 december 2019 06:06 PM
Now mechanic think that need more carefully check water pump. Maybe it is not working at it must work.
> 11000 berichten
Gepost: 04 december 2019 07:01 PM
As far as I know, all DS23 (DX4) models were fitted with the horizontal-flow, higher capacity cooling system from the IE (DX3, DX5) models. I wonder if a standard cooling system like the one shown will be enough to keep a DX4 engine cool. But I haven’t ever run a DX4 with a simple cooling system, so I wonder what others here think.
Jeroen Simons
Totaal aantal Berichten: 1460
Geregistreerd: 27-03-2011
- 2CV 2CV6
- Overig Mobylette
- C5 2.0 automaat
- Ami 8
- GS/GSA 1130 berline
- ID/DS 19b
Gepost: 04 december 2019 08:36 PM
@mr Rubins. You have a interesting but also difficult case..
If the engine runs, do you see that all pully’s and belts are turning/moving?  On the photos, i see a single belt (that doesn’’t have to be the problem, but is is not the original configuration).
Have you checked your cooling circuit with a digital thermometer, to detect hot/colt spots?
I think I see a gas (LPG) system. that means that the cooling circuit is changed.  Is the defroster and LPG Circuit connected well? LPG means high temp. Is the LPG-air mixure oke?
Is the overheating if you drive on gas, petrol of independent of that?
Last question for now: an easy check: is the cooling air inlet clean, not blocked and original configured. Cooling starts under the nose.
VrGrJ
Mr.Rubins
Gepost: 04 december 2019 10:04 PM
LPG is disconnected now. Engine run without LPG.
Totaal aantal Berichten: 43796
Gepost: 05 december 2019 07:30 AM
You are very right indeed. This engine, the 23, needs the big radiator with the separate tank.
2 van de 5
