Je CX staat nu in de garage zag ik? Ik fietste vandaag langs, omdat ik naar Sassenheim ging even een rondje fietsen. En toen zag ik haar op die middelste brug staan.
Totaal aantal Berichten: 7156
Geregistreerd: 08-08-2004
- CX reflex ie break turbo 2
- C6 (2005-2012) 3.0HDI Exclusive (te koop)
- CX 25 Gti Turbo (evoluerend)
ja klopt ik was zomerbanden aan het monteren. En ruzie aan het maken met het balanceer apparaat.
Totaal aantal Berichten: 1501
Geregistreerd: 26-11-2004
- C1 1.0i 5DRS ambiance
- C1 1.0 Ambiance
JAAAAAHAAAA! Nu weten we het wel! ![]()
On behalf of John, I am posting the following:
@ IFATFIRST.
Regards the Beast.
From what I have read, I feel I have to help you with your limited knowledge of engine tuning.1. 12v hair dryers do nothing to make power. In fact, when the engine is running near to the top end of the rev range, these plastic toys actually reduce the airflow, as they are nothing more than an obstruction.
2. Yes, you may feel you have more power, but this is a physcological gain, as your sub-consious doesn’t want to believe you have wasted money.
3. It’s also funny you say “yes very bling wouldn’t catch me doing that to a CX… might not even catch me in CX ”
4. Then you go on to say “I have a 2.0 athena with electric turbo and filter removed a mate of mine rejetted it for me it makes a lot more noise and feels a bit quicker not sure.” I don’t need to say any more, do I.
5. As for the Beast:- You cannot see what is fitted to the motor in the pictures, you do not know what fuel injectors (or mods) are fitted, you cannot possibly see what the turbo is. I should also add that it is a Garrett T3 and you may not know, but there are 4 different sized internals and ratios for this model.
6. In your knowledge of Nitrous, you do not know what fuel or nitrous pressure I run, so unfortunately you do not know the flow rates.
7. As for Neil and CGAT, I think he feels threatened that he might not have the only tuned CX around. So, he shows this by his comments. He also shows this by following me around the World to different forums and always trying to have something to say each time I make a post.
8. The engine I will be building, is being built to suit what my customer wants and is being built to suit the auxillaries that the engine will be controlled by.
9. Running around with a Dremel, Ohhhh please. Listen…...35 years experience, a Masters degree in automtive mechanical & electrical engineering being a 2:1 from London university, British and European champion when I was racing, 7 trophies – 6 1st & 1 2nd. In the 2 shows we entered the Beast in, in France, she came away with Best of show and top engine award at one show and top 20 in the other. I also looked after a Formula 3 for Renault & their Porsche cup car in between normal work and restoring their Renault 4cv.
10. Now the Beast is undergoing a complete re-build. I was hoping to get it ready for Rome, but work commitments means I will be looking at getting her ready for Eurocitro at Le Mans in 2009.
11. Knock my work if you want, but come up with something sensible and please show me your qualifications, I am always willing to learn if someone can tell me something I don’t know.
12. When the Beast is ready, I’ll be quite happy to race any other CX and then when you’ve all had you backsides well and trully smacked, you may re-think what you know and what I can do.
13. Sorry if this all sounds a bit harsh, but as I get older, I find it difficult to ignore bar room experts.
sans-pareil schreef:ja klopt ik was zomerbanden aan het monteren. En ruzie aan het maken met het balanceer apparaat.
Wanneer heb je geen ruzie met dat oude balanceer apparaat?
Hoi Wendela,
Het riekt inderdaad een beetje naar afgunst.
Ik vind het een sterk commentaar van John.
Gr Raymond
Het was een cx of niks
Hehe. Well, I have no doubts about John’s technical capabilities. The general impression I get is that, while CGAT develops lots and lots of power, Johns solutions are more…. elegant (even if his taste in bodywork is apalling
I personally have next to no knowledge for the renault motor. But, putting a bump in the hood of a CX is sacrilege, the car lives by its lines. I would recommend IFATFIRST, that you start a topic about your car and then everyone can add their comments as they see fit.
In the meantime though, back on topic, and back to dutch, as it’s all a little more mundane.
Ik heb gisteren duz inderdaad al ruzieend met het balanceer apparaat mijn zomerbanden geplaatst. Het zijn uniroyals geworden. Michelin levert niks in 205/60R15W dus ik heb maar cheapo’s gekozen van Uniroyal op http://www.novarota.nl. Minder dan 80 euro per stuk, en ze rijden goed. Het balanceren is ook aardig gelukt, gisteren binnendoor nog even de 160 aangetikt, met een hele hele lichte trilling, maar ja 2 van mijn stalen alfa velgen zijn dan ook niet helemaal mooi recht. Ik had eigenlijk een 2e setje alfa staal besteld maar de sloperij belde op dat ze ze toch niet hadden uiteindelijk. Aangezien het dit weekend 20 graden zou worden heb ik de winterbanden maar van het staal afgehaald.
Dit, samen met de andere klusjes van gisteren betekenen dat de vooruitgang vwb de motor weer eens precies nul was. Ik denk dat ik vandaag nog maar even naar Abbenes ga om toch maar wat te doen. Anders komt er nooit wat van. Volgend weekend is alweer de citromobile, maar misschien kan het op koninginnedag nog wel wat gedaan worden. Ik moet ook nog even de laatste dingetjes bij DP-engineering bestellen voor de VEMS.
elegant: adj.
[common; from mathematical usage] Combining simplicity, power, and a certain ineffable grace of design. Higher praise than ‘clever’, ‘winning’, or even cuspy.
The French aviator, adventurer, and author Antoine de Saint-Exup�ry, probably best known for his classic children's book The Little Prince, was also an aircraft designer. He gave us perhaps the best definition of engineering elegance when he said “A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away.”
Good luck with the renault engine. There’s also something called a J7T I believe it’s a 2.2liter 4 cyl 12 valve injection that makes 150hp and it’s vaguely possible it will fit straight into the athena’s engine mounts. There may also be a factory exhaust manifold from some sort of renault turbo that fits it. That would be an interesting starting point for a proper engine that I’ve given some thought in the past, never made any work of it though.
But as John says, loose the electrical blowers, get a Eaton supercharger if you must.
Totaal aantal Berichten: 3026
Geregistreerd: 22-08-2006
- BX 16 RS
uhmmm, elegant in google gepropt…
Goed nieuws uit St. Marien, de turbo situatie is ook opgelost. Als ik het goed heb, zijn er dan nu geen belemmeringen meer om het allemaal te bouwen.
En het is weer even geleden, dus weer een overzichtje:
Information for year: ALL
Spent € 28,598.87 (€ 25,660.83 ex VAT).
Spent € 24,348.87 (€ 21,410.83 ex VAT) so far. (ex purchase)
mileage first listing: 97578.00 km
mileage today: 170927.00 km
so far 73349 km driven since first listing.
8385 km driven this year.
costs are € 0.39 (€ 0.35 ex VAT) per km
costs are € 0.33 (€ 0.29 ex VAT and ex purchase)
fuel costs are € 0.17 (€ 0.14 ex VAT) per km
fuel costs are € 3,279.25 inc BTW per year
average fuel consumption within NL (at average € 1.51) is 1 liter per 9.4km or 10.7 liters per 100km
average fuel consumption outside NL (at average € 1.41) is 1 liter per 10km or 10 liters per 100km
maintenance costs are € 8,769.20 so far
maintenance costs are € 2,724.15 average per year
maintenance costs are € 0.14 (€ 0.12 ex VAT) per km
insurance costs are € 0.01 per km
road tax costs are € 0.02 per km
all costs excluding purchase and maintenance are € 0.17 per km
all costs excluding purchase, fuel and maintenance are € 0.03 per km
all costs excluding fuel are € 0.17 (€ 0.15 ex VAT) per km
Av. cost per m € 630.33 (€ 554.27 ex VAT)
Av. cost per y € 7,563.96 (€ 6,651.26 ex VAT)
Expected km per year: 22786 km
Expected km this year: 27094 km
En voor de grap eens even gekeken wat ik kan leasen voor dit bedrag… ja ja een C3 1.4 hdif ambiance. En dan om te bedenken dat hier al de kosten van de aanschaf van de VEMS en de speciale zuigers al in meegenomen zijn.
sans-pareil schreef:Goed nieuws uit St. Marien, de turbo situatie is ook opgelost.
Dus daarom komt mijn lief altijd zo laat naar bed…
Zo, de VEMS en de forge dumpvalve zijn binnen. Wat heel fijn is, is dat er al allemaal metalen puntjes aan de draadjes vastgekrompen zitten, dus dat scheelt een boel soldeerwerk. Ik ga maar eerst even zorgen dat ik met de plebtop contact kan maken met het ding, dan ga ik maar proberen de nieuwe meetpunten te plaatsen, en kijken hoe de fabrieksinstallatie het eigenlijk doet als een soort baseline. De dumpvalve zet ik er morgen gelijk wel even op.
Zo, ik heb in de lunchpauze vandaag even snel de dumpvalve er in gezet, en op weg naar huis even getest.
Eerste conclusies. Lekt minder (niet?) dan het fabrieks bosch ding. En voordat iemand roept ‘die gaan altijd stuk’, de mijn was een nieuwe, 2 maanden oud, nieuw uit bosch doos, en met de zuigtest was ie nog prima toen ik hem er af haalde. De nieuwe forge is dus echt beter.
Turbodruk loopt iets hoger op dus, en sneller. Tweede is het geluid. Je hoort echt een flinke ‘psshhh’ als je van hoge boost het gas loslaat. Is erg grappig, en niet zo hard dat het storend is. Het lijkt ook nog of ie iets soepeler loopt dan voorheen, iets minder het hikkerige karakter waar zo veel gti t’s last van hebben.
En voor de echte tuning figuren, ik ben inderdaad overgestapt van een recirculation valve naar een een dumpvalve. Een recirculation is op papier beter bij een luchtweger, maar ik ben hierbij op de ervaringen van john afgegegaan die heeft uitgelegd dat hij nooit enig effekt heeft kunnen waarnemen van het heel even rijk lopen dat veroorzaakt wordt door charge air naar atmosphere dumpen. En straks, met MAP en MAT sensoren maakt het toch niet meer uit dus dan toch liever een dumpvalve.
Om maar weer eens verder te gaan met mijn ongelezen monoloog.
Megatunix werkt op mijn plebtop (linux variant van megatune), nou ‘even’ stroom en eerste sensoren aansluiten. Oh ja. Ik moet ook nog een tik in mijn voortrein oplossen, mijn uitlaat weer vastzetten, olie verversen, een roestplekje bijwerken, hydraulische koppellingsbediening monteren (ik krijg nu echt een lamme poot van al het file rijden).
Maar ik denk dat de VEMS toch wat voorrang gaat krijgen…
